Old 10-07-2009   #1
tpepmeie
Unhappy WTB-Crankshaft plugs
All,
Have come across a problem with my crankshaft. The press-in plugs supplied by Bryant do not fit the holes in the crank. Does anyone have the factory plugs? are they NLA from GM?
Talking about the pressed-in plugs, NOT the threaded plugs. I *think* the correct size is 22mm, although the rear plug is bigger.
Thanks,
Todd Pepmeier
Old 10-07-2009   #2
flyin ryan
flyin ryan's Avatar
Default Re: WTB-Crankshaft plugs
Shouldn't be too hard to find some frost/cup plug at an auto parts store or machine shop that'll fit properly. I wouldn't even bother to try & find the corrcet one's, per application. Also...a person doesn't know 100% that Bryant didn't change the size a hair either .
Old 10-07-2009   #3
Jeffvette
These little guys #10067639
Old 10-07-2009   #4
Polo-1
Todd
You have to measure the hole. My Moldex was 7/8 + .002 The plugs come in + or - sizes. A local machine shop that does crank work can help you out, they did for me anyways. My set of stockers have no press fit to them on the Moldex crank.
Old 10-12-2009   #5
limey
in stock, pm sent.
limey is offline   Reply With Quote
