Old 09-19-2009   #1
Default Clutch order today: chk me out...
After reading all the clutch stuff of late, I think I understand the key points. So, it looks like I'm going to go with (Valeo) Duralast kit fm AutoZone with their lifetime warranty. So, check me out here:
I'll order the kit for the 93-95 ZR-1s, in hopes of finding one with the proper PP height to allow use of my stock bolts. (Yep, I realize the TO bearing is different and I'll need to have the '90 style bearing.)
Failing that, and I wind up with the LTx unit and shorter PP height, I need to trot over to GM and buy a set of LT1/4 PP bolts.
OR...use my stock PP, but check the cupping of the ring, and if there is more than .015 from outside to inside edge, then I need to go slow until the new disc breaks in a bit (running the risk of glazing the new disc and having to start over (Marc says he's BTDT.)
I hate making mistakes - nuff of that to go around this summer as it was! But, have I made the correct assumptions here (before I buy a clutch kit?)
TIA,
P.
PS: Lemme ask a stoooopid question: Would it not be possible to put a spacer under the stock ZR-1 bolt heads to make up the length difference of the LTx PP? I'm sure there is a substantiated reason this hasn't been discussed before now (that I know of).
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-19-2009   #2
Pete
Pete's Avatar
Default Re: Clutch order today: chk me out...
Paul here is the part # for the screws you need 10079898.
I don't see why you couldn't use a washer
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-19-2009   #3
Kb7tif
I contacted Bill B concerned about the new style pressure plate he said there will be no performance or fitting issues with the new style pressure plates.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
