Old 09-13-2009   #1
Default Another Water Pump Post
Looks like I took mine out by installing a new tensioner..
Well, not completely, but it is leaking I suspect..
Anyway, when I go to replace it I don't need to remove the crank pulley do I?
Old 09-13-2009   #2
Default Re: Another Water Pump Post
No, the crank pulley does not have to be removed. I remember when I did mine it was the first experience I had working on the LT5 and it's not as easy as other cars, just more stuff in the way to get to it.
Old 09-13-2009   #3
No not at all. remove the air horn and look down its really not that bad of a job. Maybe a time for new hoses while you are there Jeff!!! A lot of the mystery of the LT5 goes away the minute the Air horn is removed. I suggest making sure the bots on the pump are tight however before you tear it off the front of the block.
Old 09-13-2009   #4
Yes, go for the SAMCOs if you don't already have them.
Old 09-13-2009   #5
Got samcos on already.. I think it is the pump. There is a noise I have heard too, when running, so I am pretty sure the pump is bad or almost totally bad..
hard to see anything with the car together and pump pulley on
Old 09-13-2009   #6
Well then sounds like its time for a water pump replacement. Well at least you wont need to buy hoses. GC
Old 09-14-2009   #7
Yes, sounds just like mine....it was a very slow leak and I could not find it otherwise until I got to the pump as the drip was coming down and off another location making it seem like it was elsewhere. I hope you have a replacement already since some of the prices have gotten just ridiculous. It seems the best price ones now are from Corvette Central. At least the SAMCOs are easy to remove unlike the stock ones that seem to almost need to be cut off after awhile.
Old 09-14-2009   #8
Yep those Dorman style clamps GM used are real fun in tight corners trying to get off. Especially down by the thermostat. The Samcos are so much easier, just wish they went a little easier on the Samco logo stamp thats everywhere. To be honest however, its nice to have a vendor that still supports the LT5. Those are becoming few and far between.
Old 09-14-2009   #9
good to hear on the Samco hoses coming off. As for a pump, I do not have one yet, but the Corvette Central one seems to be the best deal, aside from a rebuilt
Old 09-14-2009   #10
jrd1990zr1
jrd1990zr1's Avatar
Jeff,
SGREG has an OEM one he has been trying to sell. Drop him a PM.
The noise you have heard can you tell when it is the waterpump? I have a noise which I think is my front alternator bearing starting to go.
Good luck with the repair, John
