For those of you that ever have removed the D/S Left Hand camcover, you'll know you probably had to remove the brake booster. In future, remove the L/H engine mount nut & jack the motor up on the L/H side, it allows full clearance of the rear most bolts, eliminating the need to take out the brake booster, which we all know if you've ever doen it, what a major pita that one is.
Takes 5 minutes of work to save 4 hours of grief. |
![]() Join Date: Mar 2007
Great tip, thanks for sharing.
#3 | |
![]() Join Date: Aug 2006
#4 | |
![]() Join Date: Nov 2007
![]() Join Date: Oct 2008
Great tip, Limey! Thanks!!
Jim |
![]() Join Date: May 2008
I visited Marc H.'s shop last year while on business in the Chicago area. While showing me around the talk turned to cam cover removal. He told me there is a way to remove the left cover without removing the brake booster assembly. I didn't pursue the topic, but the engine mount method must be the way he eluded to.
Thanks for the tip...it sounds relatively easy to do and a time saver too. Tell all...did you discover it by accident, or were you just looking for a better way? |
![]() Join Date: Dec 2004
![]() ![]() Schweeet! ![]()
![]() Join Date: Nov 2008
Do you jack up the motor in any particular spot or just on the oil pan with a 2x4?
#9 |
Great TIP :-) Where do you put the jack?
Thanks |
#10 |
![]() Join Date: Jul 2004
And how much do you need to jack by?
Great tip ![]()
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
