Old 10-05-2005   #1
Jim Jones
Jim Jones's Avatar
Location: I'm in a constant state of euphoria in the Z!
Unhappy Suffering from ZR-1 Withdrawal! :(
It all started about three weeks ago as I was taking my daughter to gymnastics, the Z started missing. I drove her the next day, not to bad at start-up, but after she warmed up she started missing. Well, not being very mechanically inclined, I did some reading here, (thanks tomtom72 for having a similar problem) and guessed that it was probably the injectors. I decided to change the spark plugs. I got out my Ouija board and contacted Houdini's spirit for luck with the number 8 plug. I don't have a lot of tools so I went and got a torque wrench and 8 Denso IT-16 spark plugs. I also got a little tool magnet that extends which came in handy on #8. I got them changed and no luck, still missing. I called my mechanic because the wife wants to take the Z to Nashville this week and last Wednesday we took the Z to Corvette Care in Columbus, OH. He's on the list in Corvette Fever and he serviced the car for the original owner, so I'm confident. As soon as I pulled in he told me he heard it missing. He called me about an hour later and said that he checked everything else before the injectors and of the 16 injectors, 7 primary were either bad or going bad and five of the secondaries as well. I told him to replace them all.
Monday I called him for an update. He said that the secondaries should arrive that day but the problem is that the primaries are on a national back order!! I said I guess this means it won't be ready this week then? He laughed a little and said probably not. He's putting AC Delco injectors back in to it. So of course the weather has been gorgeous the last several days and I can't go for a drive!!
What are the major differences between the AC Delco and the RC's? I'm thinking of calling him and having him get those. Can you mix the injectors like that? I would think it wouldn't matter, but I really have no clue.
It just makes it worse because I haven't really got to drive her in about a month because I have been working a lot and we went to Vegas for a week. I was going to take it to him that week, but he didn't have any openings. Isn't that the way it always works??
And then of course my home computer crapped out, gone, hard drive made a lovely noise and crash!! My patrol car at work died on Sunday. 2005 Crown Vic with only 8800 miles and the dealer "thinks" its the fuel pump. The darn thing left me stranded for about 45 minutes while I waited on a wrecker!
Sorry about the long post. I needed to let off some steam. This last week has really been FUN!! Anyway, I hope everyone has a great day!!
Jim Jones is offline   Reply With Quote
Old 10-05-2005   #2
Default Re: Suffering from ZR-1 Withdrawal! :(
Hope things get better soon Just go out and run the dog out of the crown vic...
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-05-2005   #3
Aurora40
Aurora40's Avatar
When I called about the Delphi injectors, they didn't seem to indicate they were on backorder. Might be worth looking into.
Old 10-05-2005   #4
Jim Jones
Jim Jones's Avatar
Thanks for the words of encouragement guys!! Delphi? I didn't even know about them. I will call!!
Thanks again!!
Old 10-05-2005   #5
Jeffvette
RC's are a stainless deisgn and will not rust and stick. Cost (discounted) is comparable with GM injectors.
Old 10-05-2005   #6
Z Factor
Z Factor's Avatar
Jim,
That is a lot of injectors to go bad all at once. You can get away with only replacing the faulty ones, but it is not a good idea to mix and match injectors.
The three things that can differ are the flow rate, the spray pattern, and the impedance. The prices can also differ as well, but it is important to match the injectors rather than mix them. Injectors from Delphi/Lucas for example have a 251 cc/min(24lb) at a static flow rate of about 44 psi, which is higher than our stock ones, which are at 220 cc/min(ie 22lb). They use a 6 hole rotary system, so the spray pattern will be similar to our OEM's, and they only cost about $40 per. If you had mods or wanted/needed to run rich they would be a good deal, but you should not mix them together. The RC's are about $70 and do have a close flow rate, I think 225cc/min, but their spay pattern is different. The OEM's will set you back about $130 per unless you can find a decent discount like I did at $85 per.
If you order from RC, you can order either the (205cc/min) injectors or the (225cc/min), with the latter in mind if you plan to mod in the future. Either will work for the LT5, and depending on who's numbers you go by, the 225's are closer to what GM had intended to be used. Since you do not work on it yourself it might make sense to just replace them all at the same time rather than have the few old ones go bad in the not too distant future, and pay the labor costs again.
Good luck
Last edited by Z Factor; 10-06-2005 at 04:13 PM. Reason: To clarify RC injector advice
Old 10-05-2005   #7
Aurora40
Aurora40's Avatar
Thanks again!!
Some more specific info can be found here, mostly on page 2: http://forums.corvetteforum.com/show...hi&forum_id=50
Old 10-10-2005   #8
Jim Jones
Jim Jones's Avatar
Update:
Well, I got all the injectors replaced with the AC Delco and it is still missing. I am thinking that I should replace the spark plug wires as well. I didn't because I love the original ones. Any other thoughts?
Old 10-10-2005   #9
Jeffvette
Should have replaced them.
Old 10-10-2005   #10
Tyler Townsley
Update:
Quickest way to check wires is to take a good spare plug and pull the plug wire put plug in boot, lay it on the plenum and crank the car. Your bad wires will show a weaker spark across the gap. Do not le it run too long as it could damage the cat.
Tyler
