08-19-2009 | #1 |
Clutch Pedal to the Floor
Yep, looks like a bad slave and/or master on the clutch. I've read all the threads and my question is, which slave has the best chance or working and which should I definetly avoid? I really don't want t do this four times like I did with my plenum
JIm |
08-19-2009 | #2 |
Re: Clutch Pedal to the Floor
contact bill boudreau. zfdoc. he will set you up .
08-19-2009 | #3 |
Don't be so sure it's the slave. Twice my peddle went to the floor and twice I thought it was a bad slave cylinder when in fact it was a broken throw out bearing. If your lucky its a bad slave. But if its not! Well then you know the rest.:-(**|=
08-19-2009 | #4 |
Start off by checking the fluid level in the reservoir. Fill it up, pump the pedal and see what the pedal does. It will only be a temporary fix. Like moving in and out of the garage.
08-20-2009 | #5 | |
thepartsladi on ebay can set you up with both Gm original parts. These should bleed out simple as a new pair. I know the slaves are 85.00 not sure on the master
1995 Convertible Supercharged Auto 1974 454 550hp (avatar car) On the blocks- -Scharger install ! 1992-Zr-1 Sold. Watson Headers Ported Plenum, Housings Random tech cats Fidanza Flywheel Chipped, Relocated Mat Woods 165 stat Borlas, Straights 1996 Lt4 Sold 1994 Lt1 Sold 2004 Z06 Sold AKA** Illenema |
08-20-2009 | #6 |
Thanks for the input. I'll contact zfdoc (Bill) and see what he recommends. I did check the fluid. It might have been a smidge low, but was black. When I bought the car I had Corvettes of Dallas go over it ans change out all the fluids. They didn't do the clutch, as they said it would cause more problems than it would fix. One year later, here I am.
Jim |
08-20-2009 | #7 |
Jim, I have the correct AC Delco/GM slave and reservoir if you are interested. Aftermarket stuff has been OK but overall can't beat factory. PM if interested. I do not have a master cylinder.
1991 ZR-1, Black, Black, # 541 |
08-20-2009 | #8 |
I appreciate it, but I've decided that with no lift and just getting my shoulder operated on, maybe I should just have Corvette's of Dallas do the deal. They are quoting me 4.5 to 5 hours labor on the master and slave. I can hardly get it apart in that amount of time.
Jim |
08-22-2009 | #9 |
Good news and bad. Corvettes of Dallas replaced both the slave and master and all is good. The a/c, however, is another story. I'll continue the post in my rabnt on the a/c crapping the bed.
Jim |
