Old 08-16-2009   #1
secondchance
Default Adding sub/amp to factory Bose
A question for audio gurus out there;
I have a 94 w/ factory Bose. Ultimately I will be going to after market system. In the meantime, I have an old Alpine mono amp and a 10" sub that's been sitting on the shelf from one of my former rides.
I was thinking about building a enclosed box and tapping off left and right rear factory speaker w/ interface that adjusts cross over htz and hooking up to sub amplifier. I did this with other cars but they were typical 4 ohms system.
Would same hook up work with Bose 2 ohm system?
The same was posted on Audio section of the other forum.
Old 08-16-2009   #2
gbrtng
gbrtng's Avatar
Default Re: Adding sub/amp to factory Bose
I don't see why not - just remember the voltage level at the 2 ohm speaker is half what it is at a 4 ohm one for a given audio signal level so you might have to tweak the input level to the sub amplifier to get the desired output.
Old 08-16-2009   #3
secondchance
Thanks for the input.
I did a quick research on the internet and it seems there is a unit refered to as line output controller (LOC). This comes in 2 channel, 4, 6 and even 8 channel configuration allowing 2 ohm speaker line input and allows for RCA jack output to amplifier/amplifiers. This should do the trick.
Ai'nt internet great?!!!
