Old 08-14-2009   #1
mkknight
Default Bolting torque convertor LT5-4L60E
Hi Guys
Can you help?
I'm going to fit an LT5 to an 4L60E and think I could have problems bolting up the torque convertor because there is no clearance to access to the bolt holes fixing it to the flexplate.The end of the drain pan is about 1/4" to the vertical face at the end of the engine.
My question is :-
If I removed the drain pan could I easierly access to flexplate holes and bolt the torque convertor up correctly? ( the corvette manual i has diagrams showing this could be possible but would like reassurance that it really does work as it directly effects whether an auto is viable)
Or is there another solution?
Many thanks
Steve
mkknight is offline   Reply With Quote
Old 08-17-2009   #2
jonszr1
jonszr1's Avatar
Default Re: Bolting torque convertor LT5-4L60E
i would pm cccamanco he has one installed in his car
Old 08-17-2009   #3
mkknight
Thanks for the cc
I've just sent him a request for thelp.
Its great you able to point me in the right direction.
Many thanks again,
Steve
Tags
drain pan, flexplate, lt5, transmission
