Old 08-13-2009   #1
JThomas
JThomas's Avatar
Default Engine Starvation / Fluttering
Within the last month, I have driven my '92 Z and have experienced a situation where the car sputtered/fluttered under acceleration. It almost seems as if the car had bad gas or something. After continued driving, the problem seem to go away.
At the time of the incident, the car had a half a tank of gas (Premium)
After the first occurence, I added an injector cleaner and last night when it happened, I added a fuel additive.
Do you think:
1. Bad gas
2. Injectors going bad
3. Clogged or dirty fuel line
4. Dirty or clogged fuel filter
5. Fuel pump issue
6. Wrong time of day??????
The car continued to drive each time, but it was a noticeable loss of power / acceleration.
Any insight would be helpful.
Thanks.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 08-13-2009   #2
Default Re: Engine Starvation / Fluttering
So does it drive ok at steady cruise but breaks up under acceleration?
Old 08-13-2009   #3
JThomas
JThomas's Avatar
Somewhat okay at steady cruise, you can sense the difficiency, but more noticeable under acceleration.
After filling the tank today and driving from Lansing to Detroit and back, no problem whatsoever. (150 mile round trip)
Joe Thomas
Old 08-13-2009   #4
secondchance
How old is the fuel filter?
Old 08-13-2009   #5
VetteMed
I was having a similar issue when my fuel pump(s) were dying. Might not be your issue, but worth checking pressure.
Old 08-13-2009   #6
rhipsher
rhipsher's Avatar
Any codes set?
Old 08-14-2009   #7
JMHO Joe.
You didn't mention any SES light flashing briefly or on, so I take it to mean "NO"?
Do you have the OEM injectors? If yes it could be the signal for the end. I don't know all the symptoms. When mine went they gave no warning that I detected. They were fine, I got gas, upon restart they were junk.
Fuel filters in C4's seem to be a bit of a mystery. I do mine every year. Okay, like back in the old days How is yours? Oh, along that vien. Do you run the gas down really low? I thinking trash in the tank sticking to the sock type of deal? If you know the filter is clean the pressure test is a bit more valid when done, JMHO.
Your narrative about the gas fill ups is/maybe a clue. Runs fine now on this last fill up? It has had the benifit of gas treatment x2...see what I'm talking about? Goes back to the trash in the tank idea.
If it was coils or plugs or wires....it don't fix itself. It's fine now, right?
Just some thoughts for you.
Old 08-14-2009   #8
JThomas
JThomas's Avatar
Thanks for all of the feedback. I purchased the car last year in April and had to acquire a lot of the vacuum lines under the plenum. (Thanks to this forum)
I don't know how old the filter is, but I believe it had been replaced while the plenum was off. I will check my paperwork from the dealer. The car now has 101,5XX miles on it. The injectors could be original or old, I don't know. When I got the car it had 97,XXX miles.
No SES lights or anything, just the sputter under acceleration, but again after a full tank, the problem seems to go away.
For now, the tank is full. I'm headed off to Woodward Ave. in Detroit for the annual Woodward Dream Cruise! If you should see a Bright Red '92 ZR-1 with the hood up, that will be me.
But the back up car will be the '07 Z06!
Let the games begin!
Joe Thomas
Old 08-14-2009   #9
Jeffvette
Joe, I'm over in London ONT if you want to come over.
Old 08-14-2009   #10
Ccmano
Sounds like mine when the secondary injectors went south. The engine would studder whenever I would get into the secondaries. But before you go after that, replace the fuel filter and check the fuel pumps. Ideally I would just replace the fuel pumps. It's just a matter of time for them anyway, especially if they are origninal. Make sure there are no bits floating around the botom of the tank. Haveing said all that chances are good that the injectors are the culprit.
H
