I'm working on a "How to" article that requires more than 6 pictures... 14 to be exact. Is the a way to post this?
Thanks H ![]() |
You can always break it up into multiple posts?
#3 | |
You can put the pics on soemthing like Photobucket and then use the embed script in the post. The images will appear. You're not uploading to ZR-1.net. Very limited space. |
![]() Join Date: May 2007
I use PhotoBucket and I am still limited to 6 pictures.
Is the embed script something different that the photo "img code" link that I use? Example below: ![]() Jim |
![]() Join Date: May 2005
The limit is set in the Admin CP and can only be changed by someone with administrator privileges (not me). I'm fairly certain that raising the limit will have a negative impact on the speed/efficiency of the website.
![]() Join Date: Dec 2003
YEP ONLY 6 AT A POP
JUST DO A 2ND POST FOR ANOTHER 6 |
Found the secret... Photoshop the pictures together so that one image contains multiple pictures. As long as you don't exceed the size limit per picture your OK
H ![]() |
