Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 08-04-2009   #1
QB93Z
QB93Z's Avatar
Default Crank Shaft Rear Seal Replacement Get Together
Come on down this Sunday, Aug 9th. Darrin, David and I will be replacing the crank shaft rear seal and clutch on my 1993 ZR-1. We start at 0900 (9:00am). Everyone is invited.
I am in Westminster, Maryland. Any and all assistance and supervision will be appreciated.
Pizza and beer!
I will eMail directions to anyone that needs them. (Approx 1.5 hour drive from Fairfax, VA)
Following the repair, there will be a group test drive on some of my favorite country roads.
Upcoming events include a rear spring replacement for Darrin, a transmission, clutch, and exhaust swap for the 1990, and a differential rebuild for the 1994.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 08-04-2009   #2
Default Re: Crank Shaft Rear Seal Replacement Get Together
Pizza and beer!
Looking forward to it Capt!
Old 08-06-2009   #3
ZRGator
I'm gonna put that on my things-to-do list and I promise to bring along my wise & mature "hmmmm" commentary as I stare at what you guys are doing...
At least we can discuss what I'm going to need to do to get the Ruby ready for NCRS judging...I signed up for the Mason/Dixon Oct. 25th meeting.
Looking forward to seeing you guys
ZRGator is offline   Reply With Quote
Old 08-07-2009   #4
QB93Z
QB93Z's Avatar
ZRGator, Glad to hear that you will be stopping by. I am expecting a good group of "supervisors".
Old 08-07-2009   #5
ZR-1nce removed
ZR-1nce removed's Avatar
Wow Capt, there will be plenty of supervision for the Capt and Lt. I guess we better really try to do this job right!
ZR-1nce removed is offline   Reply With Quote
Old 08-07-2009   #6
QB93Z
QB93Z's Avatar
It doesn't matter if you do it right or wrong, as long as you look good doing it.
Old 08-08-2009   #7
HIZNHRZ
Jim, what's up with Darrins rear spring?
Old 08-08-2009   #8
ZR-1nce removed
It is cracked/delaminated. We noticed it when we were changing the clutch a month or so ago. I got a spring from Mark Haibeck. We will let you know when we change it if you would like.
Darrin
Old 08-08-2009   #9
QB93Z
QB93Z's Avatar
The cracked/splintered part of Darrin's rear leaf spring was pretty well hidden until we removed the exhaust system to get to the clutch. Since you have been having ride height difference problems, I thought of your car when we saw what the conditions of Darrin's is. I wonder if you have a similar problem with your rear spring and it causes a droop in one side.
It might be worth checking out.
Old 08-09-2009   #10
flyin ryan
flyin ryan's Avatar
Question Re: Crank Shaft Rear Seal Replacement Get Together
Where does Marc H. get his glass springs from, you guys know? Vette Brakes maybe? Always found there stuff to be great, either Corvette or Camaro F-Glass springs.
