Old 07-21-2009   #1
scholtmj
scholtmj's Avatar
Default Pulled the plenum, now what?
Pulled the plenum for the first time with the intent to replace the coils, spark plug wires, spark plugs, starter, serp. belt and fuel injectors (FIC). My car has an idle around 1k rpm and it spits black soot out the pipes (and on to the back bumper) even when driving around with modest foot control.
Some observations:
1. Strong smell of gas
2. Air box to IH hoses are VERY hard
3. Plenum runners and IH's are NOT ported
4. All vacuum lines have hose clamps or zip ties installed (Vette Doctors most likely)
5. Secondaries move but I'm not sure I'd call it 'freely'
6. Pretty dirty for only 17k miles!
Some questions:
1. How much HP will I pick up by porting the top end on a 368 motor?
2. What's the part # for IH fuel injector gaskets?
3. Is there anything else I should replace while I'm in there?
Old 07-21-2009   #2
ittlfly
Default Re: Pulled the plenum, now what?
I'm just courious about the strong smell of gas, black soot etc... did you happen to use a scanner to check your O2's readings before you tore it down? I'm just wondering if they are scewed to the lean side or not even working properly. Just a thought.
ittlfly is offline   Reply With Quote
Old 07-21-2009   #3
tccrab
tccrab's Avatar
Looks like original Multec fuel injectors. Suspect the smell and soot is a injector stuck open.
Were any of the plugs fouled?
Really surprised that a 368 didn't have at least port matching.
Did the previous owner live on a dirt road?
It's remarkably dirty under there.
My '90 with 11k miles looks almost new by comparison.
TomC
"Crabs"
Old 07-21-2009   #4
scholtmj
scholtmj's Avatar
TomC
"Crabs"
I'm glad your motor looks new! Your pictures are going to help me put everything back where it's suppose to go when I'm done!
None of the plugs where fouled but they looked pretty dark. The first owner autocrossed this car for 14k miles in Michigan (best roads in the USA!), the second owner was an older guy who didn't care much for cleaning...I'm just getting started.
I don't think soot would be a byproduct of a lean condition, more due to running rich which points to bad fuel injectors. I don't have a scanner to check the O2 codes but I didn't have a check engine light on either.
Old 07-21-2009   #5
ittlfly
ie: If there was a vacuum leak, the exhaust gases would be scewed to the lean side. The O2's would report that condition to the ECM which in turn would fatten up the A/F mixture causing a rich condition.
Old 07-21-2009   #6
Jeffvette
Can you get a better shot of the injector housing and plenum ports?
Old 07-21-2009   #7
scholtmj
scholtmj's Avatar
Ah, I see what you meant.
Pictures of ports with Jerry's gasket for reference:
Old 07-21-2009   #8
Jeffvette
The top end has been ported, but as you have found not ported to what todays standards are. You will also find the heads are not up to standards as well.
Who did the 368?
Old 07-21-2009   #9
scholtmj
scholtmj's Avatar
Who did the 368?
Vette Doctors did it in the 90's but I don't have any information on the specs from them.
Old 07-21-2009   #10
I'd suggest the plenum and inj. housings get a up to date porting job , while your this far into the project.
