07-15-2009 | #1 |
C6 Z06 wheel/tire
Does anyone know if the new Z06 wheel/tire (Front 275/35ZR18, Rear 325/30ZR19) would fit ZR-1? Are bolt pattern the same? Rear offset?
07-15-2009 | #2 | |
Re: C6 Z06 wheel/tire
I have been looking at this very combo for some time. 18s should be ok with their offset for the front. I have been told that 19s might rub inner fender in rear. Offsets I have seen for these wheels is in the 56-63mm range requiring at least a 20mm adapter. Let us know what you've found. Darn Locobob is the guy that started all this. |
07-15-2009 | #3 |
i saw a picture of the factory C6 Z06 wheels on a C4 ZR-1 and the rears looked fine but the fronts stuck out too far. I would go with the stock wheel tire setup on the back and some aftermarket fronts with a better offset that tucked them in a little more.
07-15-2009 | #4 |
sc,
Thanks to =Jeff= and his photochop capability, here's a pic of what mine would look like with 18/19s. These happen to be Comp Grey. For my car, I would do either silver or machined face with comp grey windows. Last edited by XfireZ51; 03-08-2024 at 03:10 PM. |
07-15-2009 | #5 |
Hmm, looks like a HotWheels C4 Not too sure about it
07-15-2009 | #6 |
07-15-2009 | #7 |
So from your view Dom. It tastes good
07-15-2009 | #8 |
Lot's of info on this topic here: http://www.zr1netregistry.com/forum/...ghlight=wheels
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
07-15-2009 | #9 |
07-15-2009 | #10 |
