07-13-2009 | #1 |
PCV connector
Well I went and did it, I now own a 92 ZR 1 #178, but I already have a problem.
The rubber connector that connects the two PCV valves to a vacuum tube is too lose and I have a bad vacuum leak. I called around and found out that Chevy discontinued the piece awhile back. My man even called a place in Wisconsin but their out to. If anyone has any suggestions I could sure use them, I have a makeshift setup right now but it looks bad. Thanks in advance. Jim |
07-13-2009 | #2 |
Re: PCV connector
Congratulations!
http://www.whiteracingproducts.com/i...roducts_id=262 You don't need the whole package. Pieces you are talking about are "F" shape and "ㅛ" shaped pieces. I am indicating URL for illustration purpose. I am sure someone will chime in and suggest the best vendor to turn to. Or you can contact white racing products. |
07-13-2009 | #3 |
Re: PCV connector
Maybe you can still get in on this group buy:
http://www.zr1netregistry.com/forum/...ead.php?t=8821 |
07-13-2009 | #4 |
Re: PCV connector
Thanks guys here's the piece I needed and its ordered.
http://www.whiteracingproducts.com/i...roducts_id=260 |
07-13-2009 | #5 |
Re: PCV connector
In future try Marc Haibeck in Addison Il, your backyard
07-13-2009 | #6 |
Re: PCV connector
Marc Haibeck??? can you give me more info?
Sorry man I'm a regular vette guy, this ZR1 stuff is all brand new to me. |
07-13-2009 | #7 |
Re: PCV connector
http://www.zr1specialist.com/
I am running his chip for 94 and couldn't be happier. I understand that he is one of the best for ZR-1s. |
07-13-2009 | #8 |
Re: PCV connector
He is a ZR-1 & C4 Guru you are lucky to have him and the other Chicagoland ZR-1 guys around |
07-13-2009 | #9 |
Re: PCV connector
Might want to get the whole hose assembly, chances are over the years with heat the hose itself is dry & cracked, leaking
Mine was as most are |
07-14-2009 | #10 |
Re: PCV connector
Just want to say Congrats on your new toy!
And add another two cents for just buying the parts Phil is talking about. I did it for my 90 and the fit is great and you'll see that there will be no more vacuum leaks from that part of the PCV system....for a long while!
