Old 07-07-2009   #1
Eric870
Eric870's Avatar
Default Upshift Solenoid unpluged Why?
So this is the first time i have been under my Z sence i've owned it. I see that someone have unpluged the upshift solenoid and taped it to the side of the transsmission. Any idea why thay would do this?
Eric870 is offline   Reply With Quote
Old 07-07-2009   #2
Default Re: Upshift Solenoid unpluged Why?
To defeat CAGS ?
Old 07-07-2009   #3
tccrab
tccrab's Avatar
To defeat CAGS ?
Absolutely.
CAGS=SUCKS
TomC
"Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 07-07-2009   #4
C - Completely
A - Annoying
G - Gear
S - Selection
Old 07-07-2009   #5
Eric870
Eric870's Avatar
So is this normal to unplug? I did see the 1-4 light one time....
Old 07-07-2009   #6
Yes most members have defeated the "option" So yes its fairly common. If you want to see the shift 1-4 lift light again plug it back in. Im surprised you saw it once with the unit unplugged. GC
Old 07-07-2009   #7
Eric870
Eric870's Avatar
Thanks, Daryll..
Old 07-07-2009   #8
I would think the ECm will still fire the light with the connector unplugged
The ECM would not know the CAGS is unplugged
Old 07-08-2009   #9
True Jeff I wonder however if the ECM/CCM learns? I know most of us have CAGS deleted at the PROM level as well.
Old 07-08-2009   #10
tccrab
tccrab's Avatar
ECM/CCM don't know if the plug is plugged or unplugged and does not care.
If the solenoid is unplugged at the transmission, idiot light will come on if CAGS conditions are met.
CAGS deleted from PROM also removes "Shift" light that normally comes on around 6800 RPMS (at least on my '90, later years maybe not).
I kind of miss that.
But to be honest, when the RPMs are up there around eleventy million you've got many other things to be doing other than looking at the dash for some stupid idiot light.
TomC
"Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
