Old 07-01-2009   #1
Aurora40
Aurora40's Avatar
Default Stupid question about lugnuts
Are they 19mm, or 3/4"? The 19mm socket seems to fit tighter, though it also tends to get stuck on the lugnut when tightening them...
Bob Saveland
Former owner of #2517
Old 07-01-2009   #2
flyin ryan
flyin ryan's Avatar
Default Re: Stupid question about lugnuts
19mm always works right for me, not too tight at all. I'm pretty sure 19mm is what's called for.
Old 07-01-2009   #3
batchman
19mm = .7481"
So either should be fine. I've had no ill effects from using 3/4" long term, since I don't have a 6 point deep 19mm .
Best,
- Jeff
[/I]
Old 07-02-2009   #4
gbrtng
gbrtng's Avatar
They're metric = 19 mm.
