Old 06-28-2009   #1
Scrrem
Scrrem's Avatar
Default Change Oil Light
On the way back from the track yesterday my "Change Oil" light came on. I haven't driven the car much since I got it, no where near the 3000 mile mark. The triggering mechanisim for this light, is it perhaps a combination of mileage or time in it's calculation?
Thanks
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 06-28-2009   #2
White Bullet
White Bullet's Avatar
Default Re: Change Oil Light
As I understand it the change oil light is driven by a calculation. The ECM does the work and uses various inputs such as engine rpm, temperatures, and others are used to determine when the oil is used up so to say. The key thing is calculation is reset using the DIC. Changing the oil does not reset the calculation. So either by calculation the oil has been used up or someone did not reset the computer when the oil was last changed. Hope this helps.
1991 ZR1, White/Red.
Old 06-29-2009   #3
QB93Z
QB93Z's Avatar
Rich,
You have to reset the timer for the Change Oil Light.
Here is the procedure:
Ignition ON Engine not running.
Press the ENG/MET button twice. The Change Oil Light will flash.
Press and hold the RANGE button ('90-'91) or the GAUGES button ('92-'95) until the Change Oil Light stops flashing (goes out)
You are done.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Last edited by QB93Z; 06-29-2009 at 09:53 AM. Reason: Correct year error, thanks Jeff
Old 06-29-2009   #4
Originally Posted by QB93Z View Post
Rich,
Press and hold the RANGE button (1990) or the GAUGES button (1991-1996) until the Change Oil Light stops flashing (goes out)
You are done.
Range button is on 90 and 91
Old 06-29-2009   #5
QB93Z
QB93Z's Avatar
You are correct, thanks Jeff.
Old 06-29-2009   #6
Aurora40
Aurora40's Avatar
Did you reset the light the last time you changed the oil?
Bob Saveland
Former owner of #2517
Old 06-29-2009   #7
Scrrem
Scrrem's Avatar
That's the big question mark. The place that sold me the car in Feb said they had just serviced the car. I haven't driven it very much since Feb, so...either they lied about servicing or the tech didn't reset the light on the service. I am thinking the later just because when I checked the oil, it looks pretty clean. Just to have an accurate baseline, I may just have the oil changed so I know where things stand. It's cheap insurance
Rich
Ron Davis Radiator
Old 06-29-2009   #8
QB93Z
QB93Z's Avatar
Rich,
You are welcome to come up to my place and we can change the oil here. Bring the oil and filter of your choice we''ll "get er done".
Jim's "will change oil for beer" garage.
Old 06-29-2009   #9
Scrrem
Scrrem's Avatar
Rich,
Jim,
I may do that. I have the tools and am able to do oil changes, but I have yet to figure out a good way to get the 2 or so quarts of oil out of the oil cooler. How do you do it?
Rich
Ron Davis Radiator
Old 06-29-2009   #10
QB93Z
QB93Z's Avatar
Originally Posted by Scrrem View Post
Jim,
Rich
Rich,
I have never bothered to get the oil out of the oil cooler. I figure that changing ~80% of the total oil volume is sufficient at the interval that I use.
However, I have a neat compressed air powered vacuum container that will suck all the oil out of the cooler if we disconnect one of the hoses. Want to give it a try?
