Old 06-28-2009   #1
Question Fuel filter changeout?
Other than taking a 93 octane bath (and trying to work quickly), y'all have any suggestions on changing the in-line fuel filter efficiently?
TIA,
P.
Old 06-28-2009   #2
Aurora40
Aurora40's Avatar
Default Re: Fuel filter changeout?
It's pretty easy, not much to it. Supposedly opening the gas cap relieves a lot of the pressure, minimizing the bath. Also there's a shield in the way, but it's not hard to remove. Wear safety glasses and gloves.
Old 06-28-2009   #3
flyin ryan
flyin ryan's Avatar
It's gonna leak/drip no matter what you do. Be prepared with your tools & switch them out fast.
Old 06-28-2009   #4
I would also relieve the pressure at the fuel rail Shrader valve.Use lot of rage at the filter.
Old 06-28-2009   #5
Sgreg
Sgreg's Avatar
TIA,
P.
Release the pressure at the fuel regulator.
Sgreg is offline   Reply With Quote
Old 06-29-2009   #6
just a fwiw, I do mine every yr.
remove gas cap, do relief @ the rail, use a pan under the filter location, remove heat shield, loosen fuel lines, let drip into pan & do the trans & pan plug, take a break, when fluids stop, get back under & finish the job.
The only "quirk" is the bolt for the filter/frame clamp has the return line across it, you need to gently pry on the line to move it just a bit to get the wrench on that bolt for the frame clamp.
Old 06-29-2009   #7
Kewal! Sounds like you've done it a few times, and you have (and it shows!).
Thanks to all!
P.
Old 02-22-2010   #8
Scrrem
Scrrem's Avatar
I've never done this before so I'm going to ask a dumb question here. What's involved in relieving the fuel rail pressure. Do you just crack open a fitting?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-22-2010   #9
tf95ZR1
tf95ZR1's Avatar
Rich
Just like the air valve for your tires, there is a fitting on the passenger side
just poking out from under the front of the plenum- its on the front of the fuel rail. Put lots of rags under it and push the center pressure release pin.
I suppose you could rig up some sort of screw on fitting on the end of a tube and direct the fuel to a kinder place.
Old 02-22-2010   #10
Demps
Demps's Avatar
Go buy a $40 fuel pressure gauge at a parts store with a bleader tube.
Relieve pressure at fuel rail; drain gas in catch can. Remove GAS CAP!!! But first...be able to get under the car so you can maneuver to undo old filter.
Ted
Demps is online now   Reply With Quote
