Old 06-26-2009   #1
viperbaron
Default Lowering a '91 ZR1
What advantages are there to "lowering" a ZR1? Can it be done with the selective ride system? Should it be done? How can it be done? Just an inch or so.
With my '80, lowering the rear is easy with longer bolts, but the front coil springs are more problematic. I was wondering what it would take to lower my '91 ZR1?
viperbaron is offline   Reply With Quote
Old 06-26-2009   #2
jonszr1
jonszr1's Avatar
Default Re: Lowering a '91 ZR1
lowering the rear is just like your 80 (longer bolts . the front howevert is more involved ,you must remove the front spring which is a pain and put on a different bumper . you can find the pieces in any of the corvettte catalogs .or switch to coilovers . to me the car is low enough , my 92 has coliovers which makes it 2 in lower and it scrapes on everything ,even ants jk
Old 06-26-2009   #3
Mine is NOT lowered, and speed bumps anywhere are a certain drag! For the street, I wouldn't want to go lower. If I were tracking it...That might be a consideration...might be.
With regard to racing on a road course, I wonder what Jeffvette would have to say 'bout lowering the Z? (If anyone would have an expert opinion, he would, I recon.)
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-26-2009   #4
Another vote for not lowering it. The car is low enough and the speedbumps in my neighborhood are a PITA no matter what the angle of attack. Especially if you are running a B&B fartcan resonator on the underside in the midline. I see zero benefit beyond maybe autocross and only with the additional modification to coilovers and other suspension mods. other than that its a personal preference. GM did a very good job in the configuration the car is already, JMO your mileage may vary.
Old 06-26-2009   #5
I'm concerned with same thing only with Magnaflow resonator which is fairly large.
Old 06-26-2009   #6
Aurora40
Aurora40's Avatar
I think the main advantage of lowering the car is the visual improvement. Dialing the rear down a little helps a lot in the looks department.
Bob Saveland
Former owner of #2517
Old 06-26-2009   #7
Any comment on what it might do for traction at the track?
In that same vein, anybody have a preference on FX3 settings for the drag strip?
Old 06-27-2009   #8
jonszr1
jonszr1's Avatar
on my blk car with the standard fx3 i get the best results in the middle setting .also disonnect the front sway bar .i remove the spare tire and fill the gas tank almost all the way full they help a bunch
Old 06-27-2009   #9
Kb7tif
Also keep in mind when you lower the rear with the longer bolts what you would be doing is taking tension off the leaf spring mainly, that would give you some lowering effect. this also softens the spring tension and causes a soft bouncy ride..... The Z has soft enough springs already.
And will need to realign.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 06-27-2009   #10
Aurora40
Aurora40's Avatar
Springs don't work that way. The spring is pushing the car up with the same force as before, which is exactly the force required to counteract gravity. In order to provide that force, it will be as tensed as before. You are simply changing the mounting point, which changes the ride height.
Bob Saveland
