06-22-2009 | #1 |
Pump cycling with key on???
I'm a newbie, so this is probably a dumb question.
With the key in the on position (engine is off) a pump cycles on and off every few seconds. Is this normal? Is it the vacuum pump? Should it only cycle once before starting? Any info appreciated. Thank you. |
06-22-2009 | #2 |
Re: Pump cycling with key on???
Should cycle, but not every few seconds...must have a small vacuum leak. Would be the 'Secondary' vacuum pump. Not 100% sure what normal would be/is... , 30-45 seconds anyways. Lots of info on this subject around.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
06-22-2009 | #3 |
I should mention..., the secondaries will still work fine. The pump is really an 'Auxiliary' pump, when it cycles it's more annoying than anything else
06-22-2009 | #4 | |
Yes, car runs fine, it is annoying though. Where are common leaks found? I'll start checking, where is a good place to start? |
06-22-2009 | #5 |
If the pump cycles on and off every few seconds or it runs continuously, chances are, you have a vacuum leak somewhere in the system.
All you need should be covered here http://www.corvetteactioncenter.com/...cuum+Diagnosis
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln Last edited by WB9MCW; 06-22-2009 at 02:46 AM. |
06-22-2009 | #6 |
ball ck valves are a common thing that goes wrong . but ypu need to pull the plenum. its an easy job .just ask most of us we all havew done it a few times .do you have a fsm?
06-22-2009 | #7 |
Ck the long lead hose that goes from the pump to the plenum. Particularly the fitting at the plenum. If no leaks at the pump or at the plenum you will become the umpteenth member of the pull the plenum club !! Lots of things to check under there.
1991 ZR-1, Black, Black, # 541 |
06-22-2009 | #8 | |
If you do, you might as well change out the coils, wires and injectors as preventative maintainance. Otherwise it's not worth the hassle. H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. Last edited by Ccmano; 06-22-2009 at 09:17 PM. |
06-22-2009 | #9 |
Start with the easy section first. The line between vacuum pump and the connection to the vacuum spider (It's by the oil filter). After that, it can be a number of small things. But it's best to pull the plenum and assess everything underneath.
What is your interval of the pump running? |
06-24-2009 | #10 | |
