Old 06-15-2009   #1
DaveK
Default Oil pan removal advice
I have an oil leak from the pan and I'm going to drop it to change the gasket for Jerry's great replacement.
I know I have to remove the K brace to get the pan off, is there anything to watch out for or words of advice?
thanks
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 06-15-2009   #2
Default Re: Oil pan removal advice
Straightforward, just remember to replace the o-ring for the oil pump pick-up tube :-)
Old 06-15-2009   #3
DaveK
Thanks Jerry - I saw that advice on your site and got the o-ring along with the gasket
davidmkelly.com
Old 06-18-2009   #4
rkreigh
the little bolts up front are really hard to get to, might jack it up just a bit to give you clearance
you can pull the pan and get to those bolts without lifting the engine, but it's really tight and my fat little sausage fingers didn't fit too well.
hard to get them in there and get the threads started
clean the pan up really good as it's likely pretty nasty as this point
95 390 LPE ZR1 (505 rwhp)
Old 06-19-2009   #5
DaveK
Thanks for the extra advice, much appreciated.
davidmkelly.com
Old 06-21-2009   #6
DaveK
Does anyone have torque specs for the K-Brace bolts? Can't seem to find it mentioned anywhere in the FSM.
Thanks
davidmkelly.com
Old 06-21-2009   #7
bobbyhi
bobbyhi's Avatar
Don't start this project before your trip One thing wrong will lead to another and so on and so on. I'll end up bring my tools up to your place to get you going again
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 06-21-2009   #8
DaveK
Actually Bob, I think you're right. The oil leak isn't large enough to make changing the gasket a real necessity.
Would still like to know the torque settings for the K-brace though if anyone knows what they should be.
Thanks
Dave
davidmkelly.com
Old 06-22-2009   #9
Jeffvette
Dave, I have never found a torque spec for any of those bolts. I just use a ratcheting box wrench and use what I think is enough. Which is pretty damn tight.
Old 06-22-2009   #10
blackjack
dave,
for a lot of bolts/nuts combination,the torque settings are standard values,and you can find them in the machinist handbook...
problem is ,unless you're a machinist,you probably dont have that book...and being quite expensive,its no use for you to buy it just for that...ill dig in my stuff to see if i can post the standard values for torque settings,because unless you have some kind of special assembly built with rare,exotic and/or very special material or function (damper bolt),this is what you probably need.
bj
