Old 06-12-2009   #1
stedi
stedi's Avatar
Default Air cleaner housing
My air cleaner housing is cracked. Where can I get another one and how much should it cost? Is there a system that replaces the original (cold air intake)? I also need the accordian pipe between the housing and throttle body, mine is warped.
Thanks in advance for the help.
Steve
stedi is offline   Reply With Quote
Old 06-13-2009   #2
gbrtng
gbrtng's Avatar
Default Re: Air cleaner housing
The L98 car uses the same housing - any junkyard. Not sure about the accordian...
Old 06-13-2009   #3
I bought a duct from Corvette Central....a long time ago....it's just a copy but it works fine. I used it as a test subject to make a reinforcement liner to solve the collapse under WOT issue. The L98 duct is too small for an LT5, but the rest of the air filter housing is the same.
Old 06-13-2009   #4
65ZR1
I have two used accordians and clamps for sale. They are in good condition. Let me know if you would like some pictures.
65ZR1 is offline   Reply With Quote
Old 06-14-2009   #5
93RubyZ
93RubyZ's Avatar
Here is another option from SLP:
http://www.slponline.com/view_product.asp?P=21028
93RubyZ is offline   Reply With Quote
