Old 06-05-2009   #1
LT5-Lee
Default WTB: Phenolic spacers
Any material source or cut sets of these still floating around that need a home?
Anything to help heat soak from the Houston heat. I would also like a to find a source for the male/female IAT sensor wiring pig tail to relocate that critter also.
Thanks guys.
LT5-Lee is offline   Reply With Quote
Old 06-05-2009   #2
Default Re: WTB: Phenolic spacers
Anything to help heat soak from the Houston heat. I would also like a to find a source for the male/female IAC wiring pig tail to relocate that critter also.
Thanks guys.
You don't mean the IAC (Intake Air Controller), you must mean the IAT (Intake Air Temp sensor). You can get that pigtail from Mid America.
Old 06-05-2009   #3
LT5-Lee
Yes your right, the IAT.
Old 06-05-2009   #4
tccrab
tccrab's Avatar
SRP appear to still sell them:
http://www.zr1products.com/products.html
TomC
"Crabs"
Old 06-05-2009   #5
LT5-Lee
TomC
"Crabs"
Thank you Sir.
I see they are now 1/8" thick and ONLY $125.
Old 06-06-2009   #6
LT5-Lee
BTW, I found an IAT wiring extension.
