Old 06-03-2009   #1
rudolph schenker
rudolph schenker's Avatar
Default Tire pressure sensors.
For those that run after market wheels, what do you do about the tire pressure sensors?
Do you recommend re-installing them with new rims? If not using them will that set the light off on the DTC on a 1994?
rudolph schenker is offline   Reply With Quote
Old 06-03-2009   #2
Default Re: Tire pressure sensors.
You can pull the bulb and most will say you don't need the sensors....
Sensors are hard to come by and can be very expensive.
What kind of wheels are you thinking of going with?
cheers
Old 06-03-2009   #3
rudolph schenker
cheers
Some Fiskes came with the car along with the A molds.
Old 06-03-2009   #4
As stated most remove them. On the MY 90-91 you can pull the sensors and not see the service LTPWS light. On a 94 your only open is a piece of black electrical tape or to pull the blub as suggested.
Old 06-03-2009   #5
Fiskes are THE way to go for the Z's. I'm jealous!!!!
Old 06-03-2009   #6
ZR1Vette
ZR1Vette's Avatar
While rummaging around in my basement storage room found these things>>
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 06-03-2009   #7
limey
Those "things" are worthless now, probably worth no more than a tenner each. You take paypal?
limey is offline   Reply With Quote
Old 06-14-2009   #8
rudolph schenker
Little update......
I put the Fiskes on with the Kumho ECSTA'S and no TPS light! I purposely left the tire pressure sensors off. Makes me wonder if the system wasn't working in the first place?
Old 06-14-2009   #9
QB93Z
QB93Z's Avatar
Maybe the previous owner pulled the bulb. Turn the ignition key to the ON position but do not start the car. Look at the Driver Information Center lights. Top row, second from the right is the "Service LTPWS" light. If you don't see it, the bulb is out.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 06-14-2009   #10
ZR1North
Very nice set up - congrats.
ZR1North is offline   Reply With Quote
