Old 06-03-2009   #1
salvatore1
Default Oil Leak
Well right after I replaced my oil cooler lines I noticed another leak (puddle) -another WTF moment.
After swearing and cussing (for a moment I thought my engine block was cracked or something) - I then calmed down and started looking closer.
As it turns out I came across a sensor located below and to the left of the oil filter. This damn thing was shooting out a nice stream of oil at a pretty good rate.
I'll assume this is a oil pressure sensor of some kind. Does anyone know the part number and where I can get this thing?
Thanks
EDIT: Let me clarify. Its the sensor on the left side of the oil filter when you are standing on the passenger side looking over the engine
salvatore1 is offline   Reply With Quote
Old 06-03-2009   #2
Default Re: Oil Leak
http://zr1netregistry.com/forum/show...light=pressure
Old 06-05-2009   #3
salvatore1
Thanks
Well that was fun. I finally got the oil light sensor out. After removing the oil cooler lines, oil filter, and pushing over the radiator hose - I was able to get at that thing with a sensor socket attached to a stubby ratchet.
