Old 05-31-2009   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Steering column
While repairing the horn contacts on my 1990, I noticed what appears to be some side play whith the column. Possibly from a previous owner pulling on the wheel toward the 8:00 position. Any one else experience the problem or aware of how to make a repair?
Thanks, John
Old 05-31-2009   #2
zr1don
Default Re: Steering column
I also have a 1990 with steering wheel play in the left lower quadrant (I believe it is in the tilt mechanism). I was told there is an article in the August Car and Driver magazine about how to cure this in GM tilt columns. Hope this helps.
zr1don is offline   Reply With Quote
Old 06-01-2009   #3
65ZR1
Very common GM problem, not just in the vettes. There are three torx head screws that come loose and need to be tightened back up. They can be reached without taking out the turn signal switch but it is tight.
65ZR1 is offline   Reply With Quote
Old 06-01-2009   #4
A1990
A1990's Avatar
Anyone got a picture of the 3 torx head screws? location??
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 06-01-2009   #5
jrd1990zr1
jrd1990zr1's Avatar
Someone on the other forum sent me this link.
http://domesticmisfits.net/forums/viewtopic.php?t=124
It looks quite involved. Maybe I will fix it next winter,
Enjoy
Old 06-03-2009   #6
scholtmj
scholtmj's Avatar
My car was previously owned by a large older gentleman who used the steering wheel to pull himself out of the car. It's loose enough that you can pull the wheel down about an inch. The Chevrolet dealership said it'd be $300 in labor but I would not need any parts.
