Pretty much a stock LS7...Kinsler IR intake, Katech Torquer cam, new valve springs, retainers, Lemons' headers with 2" primaries, and a BS3 ECM. Normally this motor makes 610hp at the crank before adding a Kinsler intake. Peak torque 638/fwhp 667.
![]() ![]() ![]() ![]() ![]() Last edited by LT-5 Music; 05-30-2009 at 01:59 AM. |
![]() Join Date: Feb 2009
that is some serious eye candy and impressive power numbers.
![]() Join Date: Mar 2004
IMO Those big headers help that curve out a bit. Also IMO (FWIW) that MAY not be a 427 engine. The Tq curve appears to be that of a bigger inch engine.
Frank,
I know what you mean about the dyno #'s. But I just saw a real 491 fwhp from a street/track 323! (LS 5.3L). Those LS motors make power so relatively easy its freaky. Anyways, the LS7 went into this car. A fellow named Stuart Hayim is the customer. I'm guessing the same fellow that owns the car dealerships. I remember when Jim Kinsler first showed that intake, he guessed it would be worth 50 hp on a LS7. It was on his. And this one. Better pics are being saved for a feature in Camaro Performers magazine. ![]() ![]() |
What the hell happened between 6,300 and 6,400 rpm?
You'd have to ask the builder www.autokraft.org
Ran out of cam ! The torquer will do that.
That 69 Camaro is just ![]() Last edited by FU; 05-30-2009 at 01:12 PM. |
#9 |
#10 |
Torquer sprc's
Duration @ .050 - 220/244 Lift - .615/.648 LSA - 110 ICL - 106 (installed straight up) |
