Old 05-27-2009   #1
Scrrem
Scrrem's Avatar
Default Rear Window Replacement
OK...found new glass to replace my existing rear window but have these funny round fasteners that attach the glass to the hinge plate. Would like to use existing hinge plate, so how do you remove these fasteners? Is there some special GM tool that is required?
Thanks
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 05-27-2009   #2
Default Re: Rear Window Replacement
That top piece is bonded to the glass, IMHO you are better of painting the new piece on the hatch to match
Old 05-27-2009   #3
WVZR-1
The bond of the glass and the hinge on a 15 year old or more assembly probably isn't very secure any longer anyway. The glass on my '90 wasn't and I looked at a '94 not long ago that wasn't either.
You need a "purpose built" spanner socket or you need to be creative. Year one sells one they call a "replica" that is the correct size. Eastwood might. There's such a thing as an "adjustable spanner" also but I don't recall them doing that small a "span"!
If you really need to use your hinge plate you can be creative! Use an inexpensive socket of the correct diameter and if you've access to a grinder you'll have a "specialty/purpose created" spanner socket.
An older automotve glass shop would have the correct spanner or an older body man surely would. There's different sizes, you might want to measure center to center the two holes! If your bond is weak or broken you can ask the glass shop for a recommendation of bonding agent to secure it again.
I've seen a pair of 90* "bent nose" pliers used! Not me!
Old 05-27-2009   #4
this one?
http://www.yearone.com/serverfiles/f...archid=1968843
Old 05-27-2009   #5
Also what bonding material needs to be used?
Old 05-28-2009   #6
WVZR-1
That's the one I meant BUT I've never used. I just read my post again and I shouldn't have used is correct, I should have mentioned "likely is"!! I referenced that one so the OP had an idea of what he might be looking for.
Using that image if a person couldn't put their "hands on" one at a glass shop or body shop they could fabricate one. The correct diameter socket, a grinder or Dremel and a person would be ready quickly.
I don't recall which product we used for an adhesive. It was likely a DURAMIX product or a FUSOR product by Lord. I don't believe it was windshield urethane adhesive but I don't know why that wouldn't be a good repair or maybe even the desired! I do believe it was a "semi-rigid" product. I did that nearly six years ago.
Old 05-28-2009   #7
Scrrem
Scrrem's Avatar
As usual, you guys are the BOM! There is an existing hinge plate attached to the glass now, but it's got some dings, I would prefer to reuse mine. I will purchase the tool and see how tough it is to remove the existing plate. If I run into problems, I may play it safe and just let a glass shop do it. Thanks guys!!!!
Rich
Ron Davis Radiator
Old 05-28-2009   #8
Rich
Rich,
how bad is the plate you don't want to use? my hatch is also not attached perfect and I may attempt to remove it from the plate, but my plate is 'bowed' I might be interested in the one you don't use
Old 05-28-2009   #9
Thanks, yeah I figured that tool, MIGHT work, is it says MOST Gm products.. worth the ~$20 to try it to see
Old 05-28-2009   #10
QB93Z
QB93Z's Avatar
Rich
Rich, If you decide to attempt the repair at home, give me a call and I will come help. I seems like a job where helpers holding the glass would be an advantage.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
