05-27-2009 | #1 |
low oil pressure
my 90 ZR1 has only 8900 miles
the car is arrived in europe with 8000 miles in 91 but since 91 only 800 miles. In 2006 the motor has been rebuilt because there was a lot of water is the tank and when the owner has started the motor there was some damages. Now the problem is with the oil pressure gauge or may be the oil pressure. I had a leak from the oil pressure sensor. I have replaced the sensor yesterday. When the car is cold pressure is around 80 but after 40-50 miles the pressure is low around 0 !!!!!!! but there is no leak under the motor, from the sensor. The oil level is good. when the oil pressure gauge is around 0 I have no "check gauges" .Before I change the sensor I had this "check gauges" when the car was cold or hot. All the others gauges are OK oil temp or water temp. So can you help me ? and sorry for my english |
05-27-2009 | #2 |
Re: low oil pressure
http://w39syg.bay.livefilestore.com/...6/IMG_0607.JPG HOPE THIS HELPS
[FONT=Arial Black][FONT=Arial Black]:cool:1990 #2293 BLACK ON BLACK RED TRIM - 63MM T B - PORTED 36MM - LOWERED -HEADERS - CORSA EX - 2003 HARLEY STREET GLIDE BLACK 105 HP [/FONT] [/FONT] |
05-27-2009 | #3 |
thanks but it's not the oil temperature but the oil pressure
05-27-2009 | #4 |
There are two sensors. One for the ECM which triggers the low oil pressure and will kill the motor. Then a second sensor that sends the data to the gauge.
Check the actual pressure with a mechanical gauge. |
05-27-2009 | #5 |
Change/replace oil sending unit (the one next to the oil filter) cost $10.
Common LT5 issue/problem. Pete
05-27-2009 | #6 |
As you may know, there are two(2) oil pressure sensors. The sensor that provides the signal to the instrument panel gauge is the large one, on the top near the oil filter.
The other sensor is just for the low oil pressure warning light. It is located below the oil filter, on the oil filter housing, just below the forward, right corner of the cam cover. If you are not seeing a warning light and do not hear any engine noise (cam chains or lifters), then you probably have oil pressure even though the gauge indicates near zero(0). I would suggest installing a mechanical, oil pressure gauge (no electronic sender). A "tee" can be installed below the oil pressure sender you replaced. The gauge can be installed permanently or temporarily until you confirm the indicated "drop to zero." I don't trust the electronic gauge and installed the manual oil pressure guage on the pillar.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 05-27-2009 at 01:51 PM. |
05-27-2009 | #7 |
I have replaced the low oil pressure sensor warnig light not the other one.
I have installed a temporarly mecanical gauge. When the motor is hot the pressure is 26 PSI (in the shop manual they say mini 12 psi), not 0 but the electronic gauge says the same thing now... I wait 1 or 2 hours and I will retry. thanks for your help |
05-27-2009 | #8 | |
06-04-2009 | #9 | |
This sensor is the one thats leaking on me. It seems impossible to remove so I cannot even get to it to grab a part number. By any chance do you know the part number for this guy, and do you have any advice on how to get at it? Thanks, Sal |
06-04-2009 | #10 |
