Old 05-23-2009   #1
DTZ ZR1
Default SYS message
I have a 1990 ZR-1 and have been getting an SYS message to the left of the fuel guage. I believe it has to do with the computer or one of the systems off of it. The car runs rough in the low RPM spectrum especially when I give it the gas quickly, once I get above 3000 it seems to be fine. If I back off a little it seems to straighten up some. It also seems to be somewhat intermittent too. I do not have a check engine lite either. I have hooked it up to a code reader and it shows no codes. I need to know where to start looking. It has about 59,000 miles, I believe it still has the original plug wires, I am going to pull the plugs out today and check them. Thanks to anyone that can help.
DT
[FONT=Times New Roman]DT[/FONT]
[FONT=Times New Roman]'90 Red ZR-1 #2300 LT-5[/FONT]
[FONT=Times New Roman]'85 Bronze (Almost complete)[/FONT]
DTZ ZR1 is offline   Reply With Quote
Old 05-23-2009   #2
Jeffvette
Default Re: SYS message
Sys is more than likely due to a weak battery.
As far as the low stumble. Replace wires, plugs, possible coils and the big thing the injectors.
Old 05-23-2009   #3
DTZ ZR1
I was afraid that it could be the injectors. Will change the battery and plugs, wires and injectors. Thanks
DT
