Old 05-23-2009   #1
Default Harness bar install what do you fellas think?
I bought a used harness bar over on that other forum so Ive been a busy cylon. Install was pretty easy what do you all think of formfactor of the install? Came with both passenger and driver side left and right seat mount points for the belts. Brey-Krause makes a real nice HB. Powder coated black crinkle looks pretty good in the back interior. I was a little paranoid about the install since Phil has such a hard time with his harness bar set up in his 91 that Haibeck had to deal with. I can highly recommend this Mfgs bar. I noticed significant stiffness in the upper frame area. Car is a lot tighter now. GC
Old 05-23-2009   #2
flyin ryan
flyin ryan's Avatar
Default Re: Harness bar install what do you fellas think?
Seems all right, Daryll. Sounds good from what you say.
Old 05-23-2009   #3
Pardon my ignorance....will that set up enable you to use racing type seat belt systems? Is that what the guys that do track days ( HPDE days ) are talking about when they refer to a "harness bar" ?
Jez, I'm full of Q's, sorry...
Daryl, did you have to cut up the interrior to fit that equipment? It sure don't look like anything was altered, just bolted over stuff? It looks like the halo bar lights get covered? or removed?....I can live with that...oh, nice thumper btw!
Old 05-23-2009   #4
Sweet!
Brey-Krause makes a real nice HB. Powder coated black crinkle looks pretty good in the back interior.-Did you do this yourself?
Old 05-23-2009   #5
bobbyhi
bobbyhi's Avatar
Hey Goldie, what do you keep in that squirrel cage mounted on the back???
Old 05-23-2009   #6
Aurora40
Aurora40's Avatar
What do the seat-mount points look like? The bar looks great. Will you use a harness around the stock seat? Is it safe to do that vs having a through-the-seat setup?
I've actually thought about getting one just to stiffen the car and to mount a camera on.
Old 05-23-2009   #7
PhillipsLT5
PhillipsLT5's Avatar
Thumbs up Re: Harness bar install what do you fellas think?
Brey-Krause is Top Notch
My R-D Racing bar needed hours of modification by Marc, with no support from vendor, I have a Brey-Krause fire exting bar, also a good unit
Now you need the 5 point & Lets go racing
Old 05-23-2009   #8
Tom thats the beauty no mods. The upper seatbelt mounts are removed and supplied hardware added. The lower lapbelt mounts fit behind the seat belt retractor and the inside lapmount point fits behind the seatbelt mount insert buckle next to the console. Thanks Tom the thumper came with the car and even with the thumper box and the bar the top still fit in.
Old 05-23-2009   #9
Bob I will take some picture of the mount points I think you will be impressed I was. You last sentence was my main goal here
Old 05-23-2009   #10
Sweet!
No Lee but it was done by KB and its Jeffvette quality. I remember the crinkle PCing on the motors that I liked as well.
