Old 05-22-2009   #1
flyin ryan
flyin ryan's Avatar
Lightbulb Valve Spring Tool
Thought i'd share this with you guys. Not sure how good it will come accross in the pics, i whipped it up in the lathe, 1.5" round aluminum bar stock, to be able to utilize my valve spring compressor. The valve spring being buried down so deep is one of the things that make these heads a little more challenging to work with.
Old 05-22-2009   #2
bdw18_123
Default Re: Valve Spring Tool
That looks nice, I need one of those valve spring compressors. I wish I had access to machines to make stuff like that.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 05-22-2009   #3
flyin ryan
flyin ryan's Avatar
Just takes $$, like a lot of things. The Black one in the picture is $1000-$1200 depending on where you get it from. You can see my 'Small' one in the background hanging on the wall, it's only $350-$400ish, it would do LT-5 stuff just fine. After using these it's hard to go back to manual compressors, it's easy to get spoiled .
Old 05-22-2009   #4
4DSZR1
4DSZR1's Avatar
Holy smokes Ryan, every time I see a picture of your shop, tool or cars the area is absolutely spotless. You run an immaculate shop!
=D>
4DSZR1 is offline   Reply With Quote
Old 05-23-2009   #5
flyin ryan
flyin ryan's Avatar
=D>
Thanks Rick, . I'm usually the dirtiest thing in there, LOL. Thank goodness for Vacuum's
Old 05-23-2009   #6
Phrogs special below; and it gives easy access to pull out the keepers with the side port.
Ryan, I thought you said you were not going to touch your LT-5....looks llike you've either got it apart or working on someones
Old 05-23-2009   #7
flyin ryan
flyin ryan's Avatar
I was thinking about putting an access hole in the side, figured i'd try it this way first & see. Turns out i've got no problem the way it is, i've got a long small magnet tool i generally always use on locks & it works great in this application. Nice to be straight on from up top if you can. But either way, whatever a person is comfortable with
Old 05-23-2009   #8
Jeffvette
I've tried the cheapy phrogs method. I will say there is nothing like having the properly designed tool.
Ryan, the hole in the side will help the install of the locks.
Old 05-23-2009   #9
flyin ryan
flyin ryan's Avatar
Ya maybe...definatly seems like a good enough idea, but i've installed locks already with my tool & i don't have a problem the way it is, so for now i'm going to leave it. I'm comfortable with it. I will say, the hole in the side would be manatory if a person was using Titanium locks. Thanks though Jeff
Old 05-23-2009   #10
phrogs
phrogs's Avatar
Hey its adapt and over come. Worked for me but without access to a lathe I had to improvise
JOHNNY P
Currently own
