Old 05-21-2009   #1
Default Q for you bore n stoke boyz
I've never understood the balancing act between the crank and the piston/rods. For example: Changing to lighter piston/rod configuration does what to the crank/piston-rod balance? Showing my ignorance (again) I always thought the counter balances on the crank considered the piston-rod weights too, and changing the piston-rod weight would upset the balance...NO?
TIA
P.
Old 05-21-2009   #2
Bob G
Default Re: Q for you bore n stoke boyz
Yes It does change the ballance , but the counter weightsare not 1to1 ratio . It is a percentage of the piston & rod weights .
Bob G
Bob G is offline   Reply With Quote
Old 05-21-2009   #3
flyin ryan
flyin ryan's Avatar
This would put the crank into an 'Over-balance' situation. Would need to take weight out of the counterweight(s) to compensate.
Old 05-21-2009   #4
tccrab
tccrab's Avatar
It's all part of that "Magic" stuff that most all of know about but we take for granted because we have no idea how it's done.
TomC
"Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 05-22-2009   #5
TomC
"Crabs"
(but he ain't stooopid!)
The more I know, the more I know that I don't know...I think I'll stop learning about these "exotics" now (while I still think I know something!)
