Old 09-08-2005   #1
95ZR1#418
95ZR1#418's Avatar
Cool Need Part Numbers '95 T.O. & Pilot Bearings
Looking for part numbers for a '95 Pilot bushing(into flywheel for ZF input drive gear insertion) ant a new throw-out bearing.
Anyone know the best way to remove the old pilot bushing & how to instal the new?
Later-Bob :D
[IMG]http://www.axoplasmic.com/800x600/toponzr1.jpg[/IMG][IMG]http://www.axoplasmic.com/800x600/topoffzr1.jpg[/IMG][URL="http://axoplasmic.com/AXOPLASMIC/ZR1.html"]My '95 ZR-1 Home Page[/URL]
95ZR1#418 is offline   Reply With Quote
Old 09-08-2005   #2
Default
Hi, I looked up the GM #'s on my parts CD. A word of caution, the P/N's on the CD are old and may have been replaced by newer P/N's. Check it out at some of the sites like P & G chevy.com or GMpastsdirect.com.
Anyway:
Clutch release bearing,( T. O. ) P/n 10222087 94-95 LT5
Pilot bushing, P/N 10125896 91-95 LT5
I'm not sure but I think there is a tool you can rent at AutoZone to pull the pilot bushing. I have a 90 and the Helm manual cautions against using the "forced grease" method as the cranks are hollow(?) and damage could result making the crank unusable. I think I got that correct.
Good luck,
Old 09-09-2005   #3
95ZR1#418
95ZR1#418's Avatar
Default
Thanks Tom, those are correct numbers.
Later-Bob :D
