Old 05-12-2009   #1
rhipsher
rhipsher's Avatar
Default Injector machining done.
Injector housing and thick plenum gaskets complete. The cnc work is done.
Those gasketes almost match my table. And when I'm done with the hand work I'm going to be looking for someone to powder coat this stuff and make it look sharp again.
Old 05-12-2009   #2
Default Re: Injector machining done.
Wow, very nice work.
Old 05-12-2009   #3
Yes some really nice work!
Old 05-12-2009   #4
Jim Nolan
To each his own but, was there a reason you did not siamese them? I was under the impression that was the best performance way to go.
Old 05-12-2009   #5
rhipsher
rhipsher's Avatar
I did Siamese the plenum. I'm going to semi Siamese the injector housings only a 1/2 inch deep. But I'm going to leave a wall there to separate the primary from the secondary.
Old 05-19-2009   #6
Wait til you see what I have, apparently others have been down this road!
Old 05-19-2009   #7
Just bought two IHs.....
This one has a goldish tint to it and the following:
Is this the 90 coolant tube provision?
Old 05-19-2009   #8
Here is the other; the same as my 92
missing the breather provision.....help!
The other is 36MM, this one is the stock 31.11......and for those porters wondering how "round" the intake should be....the factory is pretty lopsided
Old 05-20-2009   #9
rhipsher
rhipsher's Avatar
Castings are not very accurate anyway. So I machined mine as symmetrical as possible. It may not be necessary. But like most machinist I'm a perfectionist. It's just a habit.
Old 05-20-2009   #10
Did you look at the top pics...those are CNCd just like yours.
