Old 05-04-2009   #1
secondchance
Default Back up light
My back-up light won't come on w/ car in reverse. I checkd fuse #28 and seems fine. Then I checked both bulbs and also seem to be ok.
Is there a switch that senses shift lever position?
Old 05-04-2009   #2
White Bullet
White Bullet's Avatar
Default Re: Back up light
Yep, there is a switch and it is located on the transmission. Seems that GM wanted to save a little $ and went cheap here on the switch. Seems to be a common problem on the manual tranny. You can replace it in place but it is not easy. Seems there are some threads around that describe the process. I am going to wait until I need a clutch replacement and will fix it the.
Old 05-04-2009   #3
Aurora40
Aurora40's Avatar
Bill B used to sell you a switch, and ship you a wrench to use that made it much easier. May want to give him a call.
Old 05-04-2009   #4
secondchance
Do you have his contact info?
Old 05-04-2009   #5
Phone (602) 319-6575
www.zfdoc.com
Old 05-05-2009   #6
secondchance
Got it fixed!
Strangest thing - I removed fuse #28 (back up light), visually looked fine but, just in case, switched it over with fuse for the horn, also 15 amp.
Then the back up lights lit up. So, I figure horn would be out. Wrong! Horn works too.
I guess electricity works in mysterious ways too...
Old 05-05-2009   #7
flyin ryan
flyin ryan's Avatar
Consider yourself lucky...the switch on the side of the tranny can be a pig. I made my own wrench, posted pictures of it a while back. Figured since i'm foolish enough to own more than one Zee the tool may come in handy down the road.
Old 05-05-2009   #8
secondchance
Yes I do!
Thanks to all for input.
