Old 05-02-2009   #1
Default Those with FIC injectors
since they are shorter, what if anything did you do different when installing?
There is 2 grooves on the top, which did you use for the clip?
Just verifying what I did, I think all is good, but don't know yet
Old 05-02-2009   #2
Toyvet1
Default Re: Those with FIC injectors
Have you started that beast yet ? The set I had only had one grove for the clip. What set did you end up with?
Toyvet1 is offline   Reply With Quote
Old 05-02-2009   #3
a set with 2 Grooves.. LOL
one groove looks to be for the clip.. the other sets the O ring a bit low for me, but might be okay
Yes Started it this Am.. idles great.. cleaning up garage tomorrow and going for a drive
Old 05-02-2009   #4
Toyvet1
What about Lake Mills in the morning ?
Old 05-02-2009   #5
too far to drive if I have issues.. gonna just drive around the area.. that will not be to later in the day though
Old 05-02-2009   #6
Toyvet1
Come on dont tell me your questioning your skills in Z repair . . . You'll be in good hands with Lee and Hans.
Old 05-02-2009   #7
Zr1 Destroyer
Zr1 Destroyer's Avatar
Here's a few pics from last year when I did the FIC injectors. The four slots that hold the rail down to the IH's had to be oblonged upward about 3/8".
out with the old...
in with the new...
Zr1 Destroyer is offline   Reply With Quote
Old 05-02-2009   #8
not at all.. my concern is the Injectors.. remember the issues last year?
Old 05-02-2009   #9
Zr1 Destroyer
I should also add that I had to push the dimple next to the screw on the injector bracket inward with my vice to allow the bracket to sit flush against the rail after oblonging the screw location.
Old 05-03-2009   #10
ZR1Vette
ZR1Vette's Avatar
Looks like a differing view on the install here... with the FIC Bosch injector package this note is included:
Thus when looking at the FIC injectors note top "full circumference slot>>>
Thus when installed looks like this>>
Also for those who use a different brand (like Accel) injector and hear about 'grinding off the tab' here is what is meant (did this for Glenn's car when we replaced his injectors)>>>
