Old 05-01-2009   #1
Kevin
Kevin's Avatar
Default replacing the amplifer relay
First off is this necessary? I've never heard of this needing to be replaced, i'm sure on a 19 year old car anythings possible.
Second how involved is replacing the relay? from what I can see it's under the drivers side dash so I'm assuming it's a pain in the ***
Old 05-02-2009   #2
PhillipsLT5
PhillipsLT5's Avatar
Default Re: replacing the amplifer relay
www.doctordon.com
Old 05-02-2009   #3
Sgreg
Sgreg's Avatar
Kevin, have no idea what your problem is but I would bet it's not the relay. If you have a volume problem in all speaker/amps it is the power module commonly known as the CDM. These go bad quite frequently in the Bose system and provide the power for nearly all functions of the Radio/CD head.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 05-02-2009   #4
I agree with Greg the CDM has gone bad. At least thats what the symptoms indicate
Old 05-02-2009   #5
Kevin
Kevin's Avatar
i think the problem is the amps and not the relay. i'm going to get then redone and go from there
Old 05-02-2009   #6
lbszr
lbszr's Avatar
Is the CDM also the same as the radio receiver box with the preamps, or the radio control head, I have similar problem with faint volume out of all four.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 05-03-2009   #7
Good timing for me. My speakers all had sound before storage and restoration. Four years later now the fronts don't work (or I should say very soft sound). So I'm troublshooting these myself to get some sound from the fronts.
Old 05-03-2009   #8
Yes basically the brain and power. If the amps were bad as each speaker is indivdually powered you would hear a lot of squal, poping and cracking.
