Old 04-28-2009   #1
Tyler Townsley
Default C 4 Frame tiedowns
C 4 frame tie downs. Since I am trailering Queenie to BG in a couple of weeks I finally wnt looking for the frame tie downs. The rear is located just ahead of the rear tire. The front is jus behind the front tire. Here are pictures with the tiedown insert.
http://www.deliquescence.net/~tyler/...20rear%20s.jpg
http://www.deliquescence.net/~tyler/...0front%20s.jpg
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 04-29-2009   #2
gbrtng
gbrtng's Avatar
Default Re: C 4 Frame tiedowns
I wonder who added those ?
Old 04-29-2009   #3
Jeffvette
Old 04-29-2009   #4
W i l l
Tyler,
That's good information. Where did you buy the tiedown inserts?
Will
W i l l is offline   Reply With Quote
Old 04-29-2009   #5
Tyler Townsley
Originally Posted by W i l l View Post
Tyler,
Will
I think it was Discount or Auto zone. I posted the pictures so you could see where to put the inserts, the ones in the pictues are the ones I put there to show how they go.
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 04-30-2009   #6
VetteMed
I'm confused -- are there factory holes that these attachment points insert into?
Old 04-30-2009   #7
Tyler Townsley
Yes these are factory holes. I believe all modern cars have these holes as they are used in shipping by rail and truck.
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 05-20-2009   #8
vettn71
Tyler,
Are all 4 attachments the same? How do you get the "T" part into the hole? It seems my 90 has very tight holes (sometimes good - this time bad)
vettn71 is offline   Reply With Quote
Old 05-20-2009   #9
Tyler Townsley
They are all the same but they are not round. They are oblong and you turn the the hook to fit into the slot then it will stay in as you pull it to the attachment hooks.
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
