Old 04-28-2009   #1
Chris H
Default basic questions
1991 ZR1 w 75k miles.
I have the start of a very small oil drip.
I was using mobil 1 (10quarts). Should I change
I like the bosch filter
what are the torque specs for the oil drain plug
what are the torque specs for lug nuts
what is recommended for coolant (I think I remember 50% distilled and something else, I'm about the pull the rad and clean it and just want to make sure im putting the right coolant in it for Florida weather)
thanks in advance, you guys on this forum have been great. Without you Id be much poorer and have a poorly running car.
Chris H is offline   Reply With Quote
Old 04-28-2009   #2
Jeffvette
Default Re: basic questions
Fix it
I was using mobil 1 (10quarts). Should I change , I like the bosch filter.
Yes, you should change your oil. Amsoil is now the oil of choice for the ZR-1. Bosch filter is fine.
38ftlbs
100 ftlbs
Any coolant meeting the 1825M spec for GM. Do not use any of the "fits all coolant" brands. Napa carries the green stuff that is correct. It comes in a blue container.
Old 04-28-2009   #3
Chris H
thanks Jeff,
Should I mix it 50/50 with the distilled???
How many quarts of oil??
How much coolant or coolant H2O mix??
Old 04-28-2009   #4
Jeffvette
thanks Jeff,
I run more water than coolant. Coolant does not have the same cooling capacity as water.
On an oil change you should add 8-9 qts.
Old 04-29-2009   #5
flyin ryan
flyin ryan's Avatar
Jeff's right, water does a much better job of dissipating heat than coolant. In summer time i tell my customers to go 70/30-80/20 water/coolant ratio. But not at the race track...water only!
Old 04-29-2009   #6
Jeffvette
Coolant is a bitch to clean off the track. Not many happy people when you blow a hose or stuff it into the wall.
Old 04-29-2009   #7
max76
Fix it
38ftlbs
100 ftlbs
Hi guys....
Another of my thousand questions:
Which is the best complete manual for Zr-1?And where i can buy it?
I'll like to buy a technical manual where i can find all the spec for lt5, with the right torque for all nuts and screw (the most important)??
Thank you so much
max76 is offline   Reply With Quote
Old 04-29-2009   #8
Originally Posted by max76 View Post
Hi guys....
Thank you so much
You want to get in touch with Helms,they made the FSM for G.M.Dont be surprised when it arrives,this thing is about 5 inches thick.
Old 04-29-2009   #9
max76
There's a web site where i can see it and know how much is it??
Thanks
Old 04-29-2009   #10
ZR1Vette
ZR1Vette's Avatar
Thanks
Go to http://www.helminc.com/helm/homepage...ls&FORM=MSNH11
The set (5 sets of documents and supplements) runs $105 plus about $16 S&H.
Coolant.... Texaco 'green stuff' also meets the 1825M spec Jeff noted
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
