Old 04-27-2009   #1
White Bullet
White Bullet's Avatar
Default Belt Tensioner
While checking the freon charge the belt tensioner was bouncing about. I replaced the belt several months ago and I am wondering how much movement should there be on the tensioner? I checked the FSM and it referenced a mark on tensioner but I was unable to locate it. So how do go about checking reference mark and how much should the tensioner move? The location of the reference mark maybe in plan site and I am just over looking it
1991 ZR1, White/Red.
Old 04-27-2009   #2
Aurora40
Aurora40's Avatar
Default Re: Belt Tensioner
Here's my idler:
http://vettetube.com/view_video.php?...663b8d9fb4be56
Apparently that is fairly normal.
Bob Saveland
Former owner of #2517
Old 04-27-2009   #3
They do bounce around quite abit,I replaced mine when I did the injectors.
Old 04-28-2009   #4
White Bullet
Aurora40,
Thanks for the video. That looks very similar to mine.
Thanks Z51JEFF,
It sounds like that after you replaced the tensioner it made very little difference. Is that correct?
Old 04-29-2009   #5
Originally Posted by White Bullet View Post
Aurora40,
Thanks Z51JEFF,
I should have clarified that after I replaced the original the new one doesn't bounce around,the original tensioner spring was weak enough that I could hold it in my hand and move it back and forth.I paid maybe $170 for mine and just found a place that has them for $110.
Old 04-29-2009   #6
Originally Posted by Z51JEFF View Post
It doesn't bounce around at all now,the original tensioner spring was weak enough that I could hold it in my hand and move it back and forth.I paid maybe $170 for mine and just found a place that has them for $110.
do tell where you found it for $110
Old 04-29-2009   #7
There is a new ZR-1 parts source I saw last night.Somebody was looking for an oil cap and was refereed to this site.I spend most of my time here or on the other site.When ever I find a new parts source I make a note of it so let me see if I can find it.Im pretty sure it was a new part but it was $110.
Old 04-30-2009   #8
vettn71
So is this new "ZR-1 parts source" secret or can you share?
vettn71 is offline   Reply With Quote
Old 04-30-2009   #9
going by what he said in his reply it is SGREG.. not sure though
Old 04-30-2009   #10
Zr1 Destroyer
Zr1 Destroyer's Avatar
Thepartslady has them on ebay..........the same people that are remaking the zr1 fuel pump assemblies.
Zr1 Destroyer is offline   Reply With Quote
