Old 04-21-2009   #1
Jarek5_7
Default iac valve and secondary vacuum pump
Hi guys. while ago I bought an iac valve, and today I bought and secondary vacuum pump. I bought it here in Poland, I found a source where they have them quite a lot in stock for now. those parts was also used in some european cars. the iac is manufactured by gm or opel I cant remeber for sure because I mounted it some time ago, the connector fits. the sec vacuum pump is with ford logo and its made in germany. I havent mounted it and I dont know it the electric conector is the same, but that not a problem.
I saw prices of those parts in usa and they are way high. If you guys want I could buy you those parts and send them to us. by one piece or soem more for a group order (that would be lower on shipping costs, but those would also be low by POST)
the cost of brand new parts would be:
iac valve - 60 $
secondary vacuum pump - 100 $
1991 zr1 convertible ;)
Jarek5_7 is offline   Reply With Quote
Old 04-21-2009   #2
phrogs
phrogs's Avatar
Default Re: iac valve and secondary vacuum pump
Do you have a part number for them you said the pump is made by ford it might be available here if we had a part number, also the number on the IAC valve.
Id like to check and see if they are.
also from poland what do you think the shipping would be to the states. small box shouldn't be to much.
thanks great find.
I could use these to rebuild mine.
oh one more thing can you open the top of the pump and take a picture of the inside of it.
you would also need to re wire for this as its a three conector and our cars only had two. 90 then 91-95 pumps.
JOHNNY P
Currently own
Old 04-21-2009   #3
Jarek5_7
ok, I`ll post the part number tommorrow, but someone told me that such pumps was used in british ford granada so it could be hard to find it in us.
if the top is not glued or something I`ll remove it and take a pic.
rewiring for difrent connector is no problem for me, actually I prefer to have spare parts like this because they can be not available in future.
as for iac I`ll look for any part number on it also tommorrow.
I dont know the shipping costs but I think it will be cheap.
Old 04-21-2009   #4
phrogs
phrogs's Avatar
If this is just like ours the top is removable it has a rubber seal around the top, but it should have wiring going to the top, thats my bigest concern.
I know a few vehicles use a pump like this I think BMW had one a few years back so it should be interesting, im just wondering about the 3 prongs ours only needed 2.
JOHNNY P
Currently own
Old 04-22-2009   #5
Jarek5_7
heres the photo of inside the pump.
