Old 04-08-2009   #1
Jagdpanzer
Jagdpanzer's Avatar
Default 8000 RPM Gauge faces for 94 95
Came across these 8000 rpm gauge faces over on ebay:
http://cgi.ebay.com/ebaymotors/RARE-...ayphotohosting
Seller says he will install them for free if you send him your gauge cluster.
Old 04-08-2009   #2
DaveK
Default Re: 8000 RPM Gauge faces for 94 95
Seen them listed a couple of times. They look a little garish to me but that could be the photography - I'd go for a white set perhaps if I found one.
Is there any reason that they are listed as 94/95 only? I thought that only the central LCD changed from the earlier versions (and lettering colour).
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 04-09-2009   #3
VetteMed
The markings on the temp/pressure gauges was different too, over the years, and the LT5 coolant temp gauge doesn't read as high as that on the L98 cars, probably LT1 too.
Old 04-09-2009   #4
DaveK
Thanks for the info VM - interesting and useful to know that
davidmkelly.com
