Old 08-28-2005   #1
Bill
Bill's Avatar
Default COOLING SYSTEM QUESTION
As some of you may know I just put a new radiator in my Vette. It works fine. Wile testing on the hiway at about 70 mph I found that by turning on both fans the temp would drop by 2º C. This leads me to believe that the incoming air is going over the top of the radiator not through it. Last week at “Glass on the Grass” in Tracy I saw a ’92 with a rubber seal between the air cleaner and the hood. Is this seal “stock” I’ve looked in several catalogs and don’t see any.
Bill is offline   Reply With Quote
Old 08-29-2005   #2
Default
I have a 95 Lt1 car that has the seal on the underside of the hood I think its to help keep air pressure at the air cleaner, but it is not on my 91 LT5 and it was not on the 90 LT5 that I had..The air going thru the Rad. should come from under the front.
I don't see how any air would be directed from under the hood and down thru the rad box.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-29-2005   #3
ZR1 MK
Default
I also tried that and had a 5 degree reduction. I thought it was my wire mesh screen creating a restriction. I will check on the way home as I have the screen off today. My system is modified, but I have sealed my radiator from air leaks fairly well. I even put a trimmed plate around the condensor tubes to reduce air leakage.
ZR1 MK is offline   Reply With Quote
Old 08-31-2005   #4
Z Factor
Z Factor's Avatar
Default
I don't have the seal you referred to either, so maybe they added it.
Besides your mods, have you added a bottle of Water Wetter? The stuff really works.
Old 08-31-2005   #5
Bill
Bill's Avatar
Default
Yes, I have been running water wetter and it does help. I think that the water side of the radiator was cloged. The new DeWitts radiator seems to have made all the difference. I'm still running water wetter, I'm sold
Old 09-01-2005   #6
Nick
Default
Where did you get the DeWitts radiator? Any pics?
Old 09-01-2005   #7
Bill
Bill's Avatar
Default
I got the radiator directly from Tom DeWitt at
http://www.dewitts.com/pages/product...asp?ProdID=300
here is a comparison picture Old vs New
