![]() Join Date: Mar 2007
What is the part number or alternative part for the fuel injector O-Rings.
Give Don (KarterDon) a call, he has them. Just bought a set today. $1 apiece.
H ![]() |
#3 | |
![]() Join Date: Dec 2003
10067600 Seal, Fuel Injector (o-ring, primary) lwr in inj hsg) 8 req'd $6.00/set I have them..... Jerry
Hey Jerry do have the o-ring on the front of the crank, for the oil pump.
#5 | |
http://jerrysgaskets.com/store/index...products_id=28 The web page shows the individual seal GM part no's, which are the same numbers I use. Jerry
maybe I have a old # ?
10067685 |
That PN is for the Seat, Oil Pump Seal, which is the steel "washer" the face of which is the opposing part to the carbon oil pump seal.
10135870 is the PN for the Seal, Oil Pump (o-ring) that goes on the crankshaft first, in the groove immediately in front of #1 main. The set I sell is for all 4 o-rings related to installation of the oil pump. I have the OEM carbon seals too, sold separately. Hope this helps. I can take a couple of photos if it helps so you can get the parts you want. Jerry
I just can read the fiche
#9 |
The pdf source I used for PN's is not very legible, so it wouldn't surprise me at all if I had mistakes in PN's.
Let me know if I can help.
