Old 03-13-2009   #1
Ccmano
Default What's the trick to getting the valvecovers off...
... with the engine still in the car? Those last few bolts on both sides are not accessable. Do I loosen the engine mounts and tilt the engine? Loosen the brake booster on the drivers side? I'm sure some body has the secret.
I'm finally getting down to installing the ported intake and want to repaint the valve covers.
Thanks
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 03-13-2009   #2
1990 415
Default Re: What's the trick to getting the valvecovers off...
on the driver's side you need to loosen the brake booster. this is done under the dash and it is much easier if you remove the driver's seat. it is a bit of a PIA to do, but many have done it.
1990 415 is offline   Reply With Quote
Old 03-13-2009   #3
I removed the Brake Booster and I also remove the Heater box piece ( the smaller) one covering the Cam cover..
careful on those Torx Bolts
now I need to refinish the covers
Old 03-13-2009   #4
Jeffvette
Start about half way down.
http://www.pnwzr1.net/LT5_tear_down2.htm
Old 03-13-2009   #5
Ccmano
Cool... thanks... Can you get away with just loosening the brake booster or does it have to come all the way out?
H
Old 03-13-2009   #6
H
well for ease of getting to the bolts, better to remove it,
Old 03-13-2009   #7
1990 415
remove the nuts on the inside and slide the booster forward a bit. it doesn't need to be removed from the engine bay. this is what i did on mine.
Old 03-13-2009   #8
Jeffvette
H
You can do it with out removing it all the way. It will get tight but you can maneuver around it.
Old 03-13-2009   #9
Ccmano
That's what I love about this forum and ZR-1 folks in general. Ask a question, get a straight answer in short order.
Thanks guys!
H
Old 03-13-2009   #10
Pete
Pete's Avatar
Stop playing games, just yank the motor, it's faster.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
