=Jeff= and myself have been working on a prototype conversion for LS-2 coils on an LT-5. LS coils is a popular upgrade for ignition systems being used by other enthusiasts. And Pete kept complaining about the cost of an LT-5 ignition module. So I decided to look into it. This conversion won't
eliminate the IM, but it will significantly reduce the heat transferred through it. Moving the coils out from under the plenum also opens up quite a bit of real estate and reduces heat under plenum due to coils. The LS2s fire in "waste spark" mode for our application. Those who are using or contemplating forced induction and higher compressin ratios, the LS2 coil packs a punch. Top end spark should be more stable also. I was able to start the motor this morning. We need to change the way we supply power to the coils, but we know what to do there. I can tell you the motor had a "basso profundo" note to it. Lower than previous. LS coils will allow wider plug gaps without taxing the ignition module. We'll add a video of the motor running later. For now, here's some pics. We're talking "proof of concept" so the install looks a bit "rough". ![]() ![]() ![]() ![]() ![]() |
![]() Join Date: Dec 2003
Hey Dom
Did it start? Pete
very nice work guys , plus it would save on plug wires
Yeah. Right up. Jeff and I just need to use a more robust source of power. But that isn't an issue. We know how to do it. Pretty straight forward modification. Had a pretty nice deep note to it. Once we get it running again I'll have you come on over and take a peek.
![]() Join Date: Dec 2005
Now All you need is plastic coil covers & A see through hood
![]() Join Date: Mar 2004
NICE
![]() Join Date: Jan 2004
Cool project
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
#9 | |
![]() Join Date: Jun 2004
#10 | |
Actually spark timing could be affected. There is a "spark latency" associated with our ignition module and the LS coils would add another layer to that. I'll need to put a timing light to it and check how much. I'd also like to think that the air/fuel combustion is benefitting from hotter spark. Here's pretty good vid on the LS coils. In it they fire a plug with a .13" gap. http://video.google.com/videoplay?do...65754251&hl=en |
