My father had a little mishap with his ZR-1 caused by sudden reduction of speed and an dramatic increase in RPM when a gearshift went down instead of up. (he was not driving another relative was).
End result was a loud knocking sound from the engine. So he is purchasing the 93 LT5 crate engine that is for sale, here to put in his car. What components does he need to purchase to make a successful swap into his 1991? Only an ECM and a prom or are there other missing components that need to be purchased? Looks like after the succesful transplant, I'll have a spare LT5 to play with. I purchased a kit from Kurt White (his old 368 kit) and need sleeves to convert my Dad's old engine. Any leads on where I can find them? Thanks, Mike Shaffer 1991 ZR-1 "the Wet Vette" Almont, Mi |
this is exactly why I don't let other people drive my car
![]() Join Date: Aug 2005
Talk to Mike at www.acsvette.com for the sleeves and many of your machine shop needs.
![]() Join Date: Dec 2003
Mike,i've put a 91 LT5 into a 94 ZR1 with no issues,you're basicly doing the opposite.
From what i can remember. You can run the stock ECM you will have to block off the EGR on the 93 motor and extend the low oil level sensor wires since the 91's have it on the left side (driver side)of the pan and the 93-95 LT5's have them on the right side (passenger side). Also use the 91 vacuum hoses since the newer motors have the differantial MAP under the plenum where as the 91's have them under the ECM All the rest is the same. Good Luck Pete
Pete, thanks for the info.
The Engine that my Dad is purchasing from ZRchris has a wiring harness and I have access to newer LT5 ECM's, looking at the wiring diagrams, it looks like most of the remaining stock wiring from 1991 will work with the 1993 ECM. So will get a new ECM and prom for a 1993, and attach it to the 1993 engine on the 1991 ZR-1. If that doesn't work, then will go with the option you proposed. Mike 1991 "wet Vette" ZR-1 1991 ZR-1 (dad's) |
If you're going to do the swap there may be a few polution sensors that are not the same, plus the harness plugs may be different.
Sounds like there were other problems with the engine. A 5-2 or a 4-1 mis-shift shouldn't have damaged the engine. LT5's a pretty bullet proof. I know I have missed a few shifts in autocrosses and have been able to recover with no problems. Aren't you the on who blew his plenum through his new paint job with wet NOS? I think we know who the driver was. ![]() |
Wasn't me this time. Was another relative, am over 350 miles away from my Dad's Zr-1.
Yup did definitely blow my intake through my hood by running lean with the nitrous. Didn't follow through and calibrate it rich enough at 176mph. Fortunately all that was damaged on my engine was my intake and hood. The "wet Vette" runs fine now. From what I gathered from my Dad on his ZR-1 was that the engine was low on oil, and a relative was playing with it hard. When my Dad went to use it, it sounded like a time bomb. The new engine he purchased from Zrchris is a crate engine with all sensors except an ECM. Any changes to the ECM inputs from the Stock car, I hope to upgrade to respective 93 ZR-1 components. I have participated in a 91 engine in a 93 body. That solution (Doug Johnson's Beast) had a 90 ecm driving the vehicle. The inverse should be true. THANKS for the info. Keep having fun driving. Mike almont, mi |
Sounds like a lifter ate it, they do not like low oil levels.
#9 |
Yea, oil levels are important to engines. Especially how much you need in an LT5. You should have your dad check the oil level in his cars before he drives them. An LT5 is meant to be driven not babied.
Good luck on the transplant, keep us posted with updates. |
#10 | |
surely it wasn't your brother now, was it? He told me he was very gentle on it and never missed any shifts. Now, let's get this story straight. Are you coming back to Carlisle this weekend? Pete Fias '95 #442 |
