smkn zr1
Only 24000 miles on the ZR1. Clutch won't engage/disengage properly. Guessing its time for a new one. But only 24000 miles???Had her at about 7000grand in first and then I could not shift out of first <yikes> Not sure if I threw a rod or what but it just seems like its not running the same. Maybe it could be because of the clutch???How much should a new clutch/pressure plate installed run me? I am guessing about $1000???Thanks, |
First check the clutch reservior, these are know to leak. It's under your ECM above your battery.
smkn zr1
First thing I did. Full of fluid. Guess its time for a new clutch. But only 24000 miles on the car... |
