Old 03-02-2009   #1
EuroPete
EuroPete's Avatar
Default '91 L98 manual gearbox, compatible with ZR-1's?
Hi guys,
Sorry if I'm asking a dumb question (I made a search and I found nothing in other threads) but here it is: I came across a ZF 6-speed transmission off of a '91 L98 Vette, is it compatible with my '90 Z? I heard the housings are different but, in case of failure of my present gearbox, could I interchange the housings?
I could get this extra gearbox at a very good price so I'm thinking about keeping it as a replacement part for the future.
Thanks a lot.
Pete
EuroPete is offline   Reply With Quote
Old 03-02-2009   #2
Default Re: '91 L98 manual gearbox, compatible with ZR-1's?
Originally Posted by EuroPete View Post
Hi guys,
Thanks a lot.
Pete
the input shaft and the collar that protrude form the front of the trans are different but interchangeable in the trans
-=Jeff=- is online now   Reply With Quote
Old 03-02-2009   #3
EuroPete
EuroPete's Avatar
So I could make a useful trans for the Z taking some parts of it, right?
Old 03-02-2009   #4
Pete
Pete's Avatar
1990-1991 should have same internal parts.
Post the trans numbers on the side tag of both transmissions the one in your Z and the L98 trans.
Also the color of tags.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-02-2009   #5
EuroPete
EuroPete's Avatar
I'll collect that information on the tags as soon as possible and I'll post it here.
Thanks a lot Jeff and Pete.
Old 02-21-2010   #6
93 ZR1 Barcelona
93 ZR1 Barcelona's Avatar
Hi Pete.
Your '91 L98 transmission is the same as the ZR-1 except for the input shaft.
But you nearly neeed to completely dissasemble the transmission to change the input shaft for a ZR-1 one, that is longer.
Next time we met, I will explain you....
I think I know where it comes that '91 trans.....
Ramon.
93 ZR1 Barcelona is offline   Reply With Quote
Old 02-21-2010   #7
EuroPete
EuroPete's Avatar
Ram?n, no worries about the trans because we sold it long ago.
Yes, you are right about the origin of the ZF gearbox
